New MEP-003A owner & Genset newbie
rickf
2,249
Pemberton, N.J.
I can tell you that Xylene works great on the fuel varnish. Carb cleaner makes it even stickier! Don't even think of your parts washer!!!!!! Be sure to clean all of the fuel pump screens.
Rick
screejunk
10
Vermont
Our advice is to never even turn the unit over until the entire fuel system has been cleaned: tank, all lines blown out, all filters replaced...Then when you crank for very short times, ensure that fuel is getting to the injector pump. Do not crank the first time with the IP hooked up...I would also pull the injectors and soak them in cleaner...Then install. Check all glow plugs and ensure they are good and working...All this before pushing fuel into the IP pump. Also make sure to clean/change ALL of the 3 filter screens in your lift pumps...This is often overlooked, but those pumps get the first whack of crap from the tank and there is usually all kinds of crap in the tanks...CLEAN tank 100%...You can put a bunch of nuts and bolts in the tank to shake around and loosen the rust...Just hope the tank bottom doesn't blow out! But one spec of rust can foul up the injector or pump...So, you need to sink time and a bit of $$ into the unit, just to crank her over for the first time with everything hooked up...More labor than anything...Your patience is key! Good luck.
Ray70
7,169
West greenwich/RI
So does anyone know what ever happened with SuperSecretSquirrel's machine? Looks like the thread ended 3 years ago with a replacement IP being on its way...
Did he ever get the generator up and running?
Gandaulf1
Yacolt
Is anyone in the Portland Or. area that can assist with checking out and starting MPE 003A? Please call Glen 360-686-0887 Thanks
