New problem found under the hood.
M1028A1ShelterCarrier
88
Mammoth Lakes Ca.
So while swapping belts today, I noticed a round sensor mounted in the block with no wire attached. The sensor looks like it has one blade just like a glow plug (unless the other blade broke off). It is between the power steering pump and the front glow plug. In my glow plug/AC wires, I found an extra green wire (same as the glow plug wires/same connector). SO does this mystery wire plug into in? Any ideas on what the sensor is? I have had no luck looking the TM's. Thanks for all your help
85-m1028
costa mesa ca.
thats just a temp sensor, the green wire goes there. You will find another one on the rear of the passenger side head it should have two tabs with green wires, that a switch for the fast idle......
I'm going wheeling monday!!! all trails should be open by now!!!!
