New project-M59
jeffhuey1n
SMSgt, USAF (Ret.)
1,603
Laramie County, Wyoming
Today, after charging the battery overnight, I reinstalled the battery. I poured gas down into the carb and checked to make sure fuel was getting to the carb from the gas tank. I crossed my fingers and ... forgot to change out the spark plugs. So, changed the plugs and set the gap to .40. Not sure if that's correct or not. Back to crossed fingers, hit the start button... oops, almost forgot, had to pull out power switch, then hit start button. Starter engaged and turned over the motor. Nothing else happened. Just for giggles I regapped the plugs to .30. Still nothing. So, after venting a bit, I started chasing wires. I know the starter wiring is good. I also get continuity on all wires up to the coil. I had to stop at that point cause it were getting dark and cold. Tomorrow, I'll check the coil and see if spark is getting to the plugs.
jeffhuey1n
SMSgt, USAF (Ret.)
1,603
The solution was too easy, with hndrsonj's leadership and a phone call, the problem was found to be dirty points contacts. A little filing with my very old point file, it started sparking. We put everything back together and she started right up. Woot, Woot!!
jeffhuey1n
SMSgt, USAF (Ret.)
1,603
Moved the truck next to the shop today and tried to knock a few pounds of gack off with the pressure washer. Not real successful but I know which degreaser to use. Also started pulling off the front cap. If the weather holds, I should be able to get the old cab off.
