New project
cucvmule
collector of stuff
1,165
597
Crystal City Mo
Is the purple wire hooked up to starter solenoid or have you checked CUCV wire diagram in the TM's?
I posted the CUCV wiring diagrams to help look at the wires to the starter and glow plug systems to help get started. Takes out some confusion.
Thank uncle sam
cucvmule
collector of stuff
1,165
597
Crystal City Mo
The starter relay under dash by the diagnostic plug may be sticking. Or depending on what prior owner has done to the steering column the starter pushrod that runs on the down side outside column to the push relay on column may be wedged in the start position. Kind of confusing but the key switch on column is just a lockset.
cucvmule
collector of stuff
1,165
597
Crystal City Mo
Well you definitely need the purple to control start at the key unless you want to bypass to start from out side with remote start.
Find purple in harness starter side of engine compartment.
What ever you do not overload circuit, keep starter cables loose to pull off in panic. Have gloves, do not get burned, have glasses on, sparks at batteries are dangerous.
cucvmule
collector of stuff
1,165
597
Crystal City Mo
Did you see the post, thread about CUCV wiring schematic?
That will give you something to look at and hunt down your separate components.
Good Luck, hope that helps.
