New Purchase Globe 10 ton trailer
20,744
Im sorry i should have been more specific im looking for the air lines
Is it the plastic lines that feed air to the axles?
Maybe a picture just in case?
If you need that black plastic line, it is a DOT Approved line that needs to be replaced with same. TruckPro is a good source. NAPA could also be an option where you are. It is just standard air supply line. Reasonably cheap and don't hesitate to get extra so you can have some in your towing vehicle in case you need it.
simp5782
Feo, Fuerte y Formal
9,509
Mason, TN
Just use coil lines and run them thru the handle on the front of the neck then around your bumperettes it will push the line along that smooth bumperette and not pinch as it's higher than the trailer frame
If you use rubber again run them thru the drain holes in the box out the bottom and loop them down and to the truck so they clear the swing
