davidkroberts
- 24
- 38
- west tennessee
I mounted a set of 2 1/2 ton tires 11.00 R 20 Michelin XL's on my stock Unimog 404. I had to remove the rear wheel wells for clearance but the front is fine. If your into heavy wheeling you might have clearance problems with the axle articulation but i dont so now i just have a truck that can easily cruise 60 now.
It really looks mean now. The first 5 gears arent underpowered at all but 6th is a bit soft. Make sure you get a good even stretch or a slight downhill to get up to cruising speed
