New steering wheel
beastm35
plainfield ct
Hello all, I just got done putting a new steering wheel. The old one was cracked and looked like crap,anybody looking to do this job get a steering wheel puller or your cutting the old wheel off.The new wheel looks great and works well its 18 inch vs. 20 stock wheel not much different for turning.
sgms18
85
North Augusta SC
I too am going to have to replace my steering wheel eventually. Did you use a standard steering wheel puller or is there one specifically for the M35?
Floridianson
2,438
Interlachen Fl.
Picked up the one for the OD stuff years ago and never used it. Even came with the original paper work. Do believe some have used what they got in there toy box.
pjwest03
35
Vestal/NY
I used a large split bearing puller behind the wheel and a 3 jaw puller on that. They were the available items in my shop.
URSATDX
So Jersey, NJ
I tried soaking it in penetrating oil, etc.
I rented/borrowed one from the local Auto Zone.
The tool bent/broke while trying to remove the old wheel.
I tried soaking it in penetrating oil again.
Ended up cutting the old wheel off to the hub and beating it with a BF hammer.
It finally came loose.
beastm35
plainfield ct
The only problem I had was where to put the center point of the puller because of the horn button and the hole for the wire is to big the puller center go's right though it.even if you put on the nut loosely,I got shocked when the center pulley screw touched the horn button. I'm just glad that job's done. Hopefully the new steering wheel last's as long as the old one did.
