New to me Humvee
lowell66dart
Paulina La.
It does have a tag. I'll get a pic and post it. Maybe someone can tell me what it means
I went for a couple of short 15 minute test drives this afternoon. Drives and shifts nice. Does not leak anything so far. All the gauges and lights work.
It has three Wranglers and one BF Goodrich so that has to change but I can let go of the steering wheel at 45 and it tracks straight.
Does anyone know what the stenciling on the front and back means?
I am pretty pleased so far being this thing was 15 minutes away. My wife told me about it!!!
juanprado
3,175
Metairie/La (N'awlins)
Welcome to the madness.
I am not too far from you.
Are you aware of the deep south Rally this weekend in Hattiesburgh?
Did you register and title yours already?
lowell66dart
Paulina La.
I know all about madness. I have had numerous 4x4's, built my own Harley, drag raced a high 9 second car for 10+ years etc. Currently have eight various Allis Chalmers and Farmall tractors ranging from 40 to 160 HP to farm about an acre and a half of Perique tobacco. You cigar smokers may know something about that.
Yes we are about 45 minutes away.
Al told me about the rally but I have a family crawfish boil thing going on.
I bought it yesterday and when to my agent. may have to go the collector car route for insurance. PO plated and titled in Louisiana BUT he got a letter. Came from OK where it was titled. Once I have the insurance I will give it a shot.
Hers a pic of my tag and does anyone know what these brackets are for?
juanprado
3,175
State Farm insured mine. My 5 ton is with Gulfway out of Fl.
We are working on the bill as you know. Hopefully good things will happen....
The triangle data plates are for MWO. Updates done since it was built. That ones appears to be for 3pt seat belts:
https://www.steelsoldiers.com/showthread.php?164864-M998-MWO-s
Zev - GoldnEagle might have a tire in Slidell. Send him a PM.
Post pictures of both sides of your bumper numbers and some of the members here are very good at deciphering.
Is that bracket on both sides of the tailgate?
Bulldogger
764
Quantico VA
Welcome! I am partial to the gen 1 HMMWV's too, having one as my only experience with green iron.
That vintage should also have another MWO for the improved parking brake. You could google that and check yours. The upgraded parking brake functions better. It was an MWO many many years ago, which should have affected yours.
I recommend doing the entire lube order, available here: https://www.steelsoldiers.com/showthread.php?78861-TM-s-for-the-M998-series
and that link has the Tech Manuals as well.
You don't have to open and inspect the hubs if you really don't want to, but at least drain them and inspect the drainage carefully. If it's not pretty, clean gear oil, an open and inspect is in order. When hubs fail, corners of HMMWVs fall off at speed...
Give her a going through, and ride the wheels off her! (Figuratively!)
Welcome again,
Bulldogger
lowell66dart
Paulina La.
Thanks guys. The brackets near the tailgate are on both sides. If you look closely at the picture you can see a Velcro strip in there.
Ordered a tranny filter today and picked up an oil filter. Hubs, diffs and cooling system are next.
I just finished building and installing a ground kit. It did NOT cure my flickering headlights or change the pulsing wait to start light. It starts right up so no big deal yet.
juanprado
3,175
I suspect maybe the brackets are for combat Id panels but I have never seen them in the rear. I have seen special brackets on the hood & brush guard, and seen them on sides but I think that might be just velcro.
flickering is probably the grounds but check them all. Ground kit can not hurt.
My wait light would only light for a nano second but everything worked ok. I changed the temp sensor/glow plug controller with the large black connector on the crossover tube and wait light comes on and works perfectly now. YMMV
131
Poplarville, MS
44 Medical Brigade, 4th Combat Support Hospital. That thing should be a cherry!
From Ft Bragg, NC
131
Poplarville, MS
Brackets are for convoy signs. “Convoy Ahead” or even signs in Arabic telling Hajjis( oops, ‘local nationals’) to keep back 500 feet.
lowell66dart
Paulina La.
I rolled around under this thing on a creeper today and I agree it is cherry! When I had the doghouse off I noticed the rust on the heads. They did paint the heads at the factory correct?
I got Hajji brackets!!!!!!!
Thanks guys.
Wire Fox
162
Indianapolis, Indiana
Thing I love about these 2-man HMMWVs...check out one of the field medical field manuals...one talks about medevac and casevac, and details ways in which you can load wounded soldiers on litters into various vehicles. A 2-man HMMWV carrier 5 hurt GIs on litters...2 in the bed of the HMMWV, and 3 above and perpendicular to them, across the troop seats. If you go in there and remove the rear seat bases, you can also fit several water and fuel cans very low and out of the way. Just check the stowage guide for an M1097 Prime Mover in the -10 operator manual...you'll see all kinds of great things that you can do with a 2 man cargo variant. Way better than carrying just 4 people uncomfortably and some armament to support them, if you ask me.
lowell66dart
Paulina La.
Sunday morning I'm heading to work when no one is around and have a printing party. Trees ARE crops.
Got the oil changed today and got grease in every zert. Ordered a tranny filter. Straightened out the brush guard.
Also determined that I have a 6.5. That's explains the flash rusted heads I guess.
Action
1,564
East Tennessee
The headlights will pulse bright/dim for a few, after starting. The volt meter will also move back and forth.
You probably have thos brackets on the fender sides, above the rear tires?
98G
Former SSG
4,866
That headlight pulsing and volt meter swing is electrical load caused by afterglow on the glowplugs, as an aid to keeping it running until it gets warm.
Feature, not bug. :)
