New to me m59 dump truck...
Evil Dr. Porkchop
351
Colchester, VT
You really need to get the m108. I hope one day to find a nice dump
An m108 has been on my "gotta have it" list for a while now. I'm sure there are plenty out there that would be a much easier restoration than this one.
Any idea what year M108 that is?
It's a 1953 Studebaker.
It's got a good frame so technically it's savable. The downside is it needs all new sheet metal, a cab/doors/all glass/top, rear axle shafts, a radiator, 11 tires, new wiring, seats and tons more for sure. The transmission and winch PTO are gone, the transfercase PTO and crane driveshaft are gone, all the outriggers are gone, it's missing the crane cable/end pulley, all the hoses are junk of course. The cab mounted floodlights were on it when it was here in the yard in the 90s but they've gone missing sometime in the last 20 or so years. I'd guess that the boom hasn't moved since at least 1991 because it's also shown in the same TV program as my dump truck and it looks like it's still swung to the driver's side back then.
Sounds like a great project truck.:shock:
Redpawn
St.Cloud FL
:shock::shock: Guess mine isn't in as bad a shape as I thought. Do you know if they would sell it as is? I might need a boom for mine.
Evil Dr. Porkchop
351
Colchester, VT
I'm going to try to get it home to VT at some point soon for a future project. Maybe there's one out there with a good boom and a few outriggers, that could help us both out :).
hndrsonj
Senior Chief/Moderator
359
Cheyenne, WY
So to recap on the 215-59 bed differences, the beds themselves are the same correct? The tailgates are also the same. The bed protectors are the only thing different (with the 215 being taller). Am I correct? Why would they cut the rivets on the front? wouldn't it be a lot easier to just remove the 2 bolts? Last question, did you ever try to just remove just the bed without the subframe?
Evil Dr. Porkchop
351
Colchester, VT
I didn't notice any differences between the subframes, beds, or tailgates (except the style of tarp hooks which is probably unrelated). The cab protector is a little bit taller on the m215 than on the m59 I've measured. If you're talking about the rivets on the front subframe mounts then those were cut because the previous owner was swapping the bed over to an m35 chassis so he needed the frame side brackets.
On the m215 I did remove the bed from the subframe first. It was fairly straight forward since I had equipment to support it while unpinning the piston.
Mackafd
Walnutport pa
Beds are the same I have a sub frame for sale I was keeping as a spare for my truck. The Bed comes off easy from the sun frame.
hndrsonj
359
Cheyenne, WY
If you remove the bed and subframe together do you have to break into the hydraulics or does it also come out with the subframe as an assembly?
Evil Dr. Porkchop
351
Colchester, VT
No hydraulic work needed, just have to remove the driveshaft between the PTO and hydraulic pump and the two control rods. The pump hangs down a bit so you’ll have to lift the bed higher to clear the truck frame.
  • Like
Reactions: HDN
cattlerepairman
3,537
NORTH (Canada)
@Mackafd That subframe assembly looks as if it weighed half the payload of a Deuce already! So this is complete with pump, just needs the PTO part set up and a tank? Out of interest, is it difficult to adapt a suitable dump bed to it?
Mackafd
Walnutport pa
No should be very easy to adapt to any bed since it’s a flat frame just bolt a bed to it some welding of a plate or two. I am selling the frame I have for $400 includes pump cyl and subframe. Eastern PA
cattlerepairman
3,537
NORTH (Canada)
Looks like a fantastic way to build a dump truck; no futzing around with cutting frame and welding on hinges etc. Thanks for the details!
