kiddra
- 0
- 1
- Port Orchard/ WA
I am new to the MEP-802a world. I just purchased a unit from iron planet. I hope to pick it up in the next couple of days. This unit looks complete but it was not tested due to no batteries. It has 35 hours on the counter but I'm not sure if this is accurate. I plan to conduct all of the regular maintenance prior to attempting to start i.e. oil, coolant, new batteries, and checking fuel system out. I have seen all kind of helpful posts here on repairs. Is there anything else I should check prior to starting? I may try to soak rings with oil prior to cranking engine. Would I add oil through the injector openings by pulling the injectors? I will also conduct the excite circuit mod and MOV mod if already not accomplished. Thank for any input you could provide.
