Augi
- 42
- 28
- SF Bay Area
After making a bunch of cellphone only adapters that don't pass the PTT signal that a radio would need to operate I decided to design and build a prototype adapter that allows you to connect ham radios in addition to cellphones to the VIC intercoms. The audio paths are selectable between 300 and 600ohms nominal which I expect will work with most ham radios, but being just a guy on the internet can't promise anything specifically. I don't have the time or radios to research or test even a fraction of what exists out there.
My new board hides in plain sight by replacing the guts of a VIC-1 C2298 crew box and it allows you to connect any combination of two radios or cellphones to your VIC system.
The audio and the PTT signals are all protected by a 750V isolation barrier so the 24V system will play nice with 12V and lower electronics.
There are a lot more and more expensive components here so I'll probably have to find a company to stuff the boards, plus I have to find a source of C2298 boxes. Because of that think these will probably be in the neighborhood of $300 if I make a batch of 20ea.
I will supply a pair of mating U229 connectors but the end user will have to provide their own radio-side connectors and assemble the cables and get their own cables to go between the adapter box and VIC head unit.
Please reply and tell me if there is any interest in these boxes. If I get a strong response I will start looking for parts.
Augi
Augi
