New whistler turbo?
gimpyrobb
dumpsterlandingfromorbit!
27,787
779
Cincy Ohio
Another thread had some info on the C and D block differences and among other things the D block has an updated headgasket that has two tabs that stick out a bit between the two heads visible from the outside. My block doesn't look like it has them so I am determining it is a C block. The block data plate is intact and mostly legible, where does it have a designation between C and D?
While this is a little O.T. The "tab" head gaskets are the old style.
HASSON1911
24
roseau/mn
I know this is a dead thread but maybe a new posts will help it out. On my M342a2 I got my truck running strong yesterday, but my whistler doesn't whistle at all. I am 100% sure that it is in fact a c turbo after measurements and pictures. So does anyone know why this whistler wouldn't want to whistle? After running it and building oil pressure I didn't lose any pressure or burn any oil, that a faulty turbo would do. Also, the engine purred like a cat. Sounded normal all except that turbo not whistling.
HASSON1911
24
roseau/mn
Caliber, I think I will try that next time I go home. Oh and dave by "purr" I mean scream and by "like a cat" I mean banshee. Jut like how they normally sound
AceHigh
31
Lake City FL
I found out my whistler is doing just fine. I stopped in at Little Caesars pizza, parked about 35 feet from the drive thru window and left her running. While at the counter the drive thru girl took her headset off and called to the manager that there was something wrong with the wireless intercom. Said it was a loud squeal. Manager said someone parked a big truck and it was interferring...
I got my order and quickly trotted out.
swbradley1
Modertator
1,939
Dayton, OH
A C turbo won't make any noise at all if it is not spinning. I started my truck last week and the turbo was as quiet as a D for about 5 minutes then it started whistling nicely. You could have a bad turbo.
I only keep a C around to irritate Gimpy, he hates them.
HASSON1911
24
roseau/mn
I talked to my dad today and he took off the intake pipe. One internet cookie for caliber. The old oil apparently set-up in there causing it not to spin little WD-40 and she is whistling better than ever. Thank you. And dave that one went right over my head but makes sense now. haha :beer:
jasonn
balto. md
Just a thought but your exhaust pipe may be corroded enough inside that it is interfering with the sound it would only take a min to unhook it and look in with a flash light.
