New young guy with a XM211 and lots of questions.
BalooGreen
TN
Howdy everyone. I just bought a 1953 XM211 and comes with that are a few problems and lots of questions. I'm just 19, so any pieces of advice big or small will be greatly appreciated. I'm currently going to college full time and working 2 jobs. One as a docent/tour guide at a civil war plantation and then a worker at a formula 1 car shop during the week. Thanks for yall looking.
~Tyler
firefox
General
51
Berkeley CA
Welcome to Steel Soldiers. Great bunch of folks here. Be patient and read as
much as you can. You sometimes have to search a bit, but most of it is here.
Good Luck
m1010plowboy
2,784
Edmonton, Canada
Welcome to the Early Deuce Decent Docent Formula One racing Team, the EDDDFORT. I'm also 19....X2.75 and drive my 56' 6x6 M135 like a formula car. The big question is, whatcha gonna do with That? I decided to go original, use it for parades and as a dedication platform to my military buddies. Congratulations on the purchase and let us know what you need to get your new ride on the track.
M543A2
12
Warsaw, Indiana
For one thing, on the bottom front of the transmission there is a large cover held on by many bolts. Under the transmission case are plugs labeled "water" and "oil". This bottom compartment is the oil cooler/heater for the transmission. Drain the coolant by removing the "water " plug then remove the front cover. Make sure all of any settled in crud is washed out of this compartment. It is a low point in the cooling system so lots of it likes to settle there. If there is enough crud there to be covering part of the internal element, it will affect the cooling and warming of the transmission oil. Probably garden hose pressure will be enough to clean it out. You do not want to damage the internal element you see in there; it has the transmission oil in it.
In cold weather this "cooler" keeps the transmission oil at engine tempreature and in hot weather it helps cool the transminniopn if the temperature there gets higher than engine oil temperature.
dmetalmiki
2,030
London England
Welcome to the site, hobby, friendships and (very many) events to come. Starting out young is the way to go, And keeps the hobby and 'green stock' rolling.
NDT
6,717
Camp Wood/LC, TX
Welcome Tyler, was a long time ago I also was 19, in college, with one job, and bought a M211 with some issues as well. Mine had a thrown rod! I fixed that, and drove that truck for years. Still have it 34 years later. Hope you follow suit!
