Newb Needs Tire Advise Please
jsrovers
Hopkins, MN
Hey everyone,
I just bought a 1987 1 ton 6.2l diesel Chevrolet military pickup and it needs tires in the worst way. In stock form what is the largest tire I can fit on the vehicle? I am planninng on putting something a little more aggressive and want to gain as much speed as I can without having to lift the truck. Any input would be much appreciated.
11Echo
92
CT W. R.
Hey everyone,
I run 255/85-16 BFG Muds. They are 33.3" tall and require no modifications to run with the stock wheels.
rizzo
Port Huron, MI
I run 315/75 R 16 good year MTR's. I had to cut little pieces of sheet metal off the inside of the fenders on the front. I also think the tire hit the fender while offroading. soooo you may wann stick to the smaller tires.
jsrovers
Hopkins, MN
Thank you for the help. Through some more research I have gone ahead and ordered a set of five 285-75-16's. Going to have them mounted, balanced and do a front end alignment all at the same time. Shortly after I am welding some new cab corners, putting on new front inner fender wells, installing new interior and the truck is getting repainted. It only has 13,275 miles on it so it should look and feel new again!
11Echo
92
CT W. R.
Nice looking truck there 11Echo!
Thanks. Other than the new tires, I have not done anything to the truck.
The original poster moves fast. I had been looking for more tire info for him and he already has ordered tires. I guess I'm getting slow!
These tires all have some height without being real wide.
