Newb Oil question
Dmaxcc6spd
KY
I searched the forums, but had too many results to be useful, so forgive me for beating the dead horse.
My recently acquired M925 could benefit from some better cranking speed. I'm still sorting out the batteries and cables, but they should be OK.
From what I have learned, it seems the engine was filled with SAE 30 oil by the govt. Is this likely?
I am planning to go with the traditional 15W40 which should hopefully flow better in the cold and promote easier cranking. I could do the 5W40, but that is really expensive.
Thoughts for the newb?
Thanks guys - I have much to learn!!
BigWill1985
Norfolk, VA
I have used Shell Rotella 15w-40 in all of my diesels for the past 4 years. I have ran it in our Vermeer wood chipper (runs a Deutz 3 cylinder 30hp diesel), my old Chevy 6.5TD, my 2006 Chevy 2500HD Duramax truck, and now our M817. My Duramax now has 295,000 miles and runs perfect! Must be something good in that oil!
~Will Courtier~
rangereter
Natural Bridge, ny
Most engine oils smell more different than they really are... 15w-40 works just about anywhere anytime in the lower 48, there are only so many refineries and it seems very proprietary with respect to additives. Most of the time two good 900 amp batts will effectively crank an 855 above 32 degrees. You might have weak batteries or poor connections? or your starter amp draw may also be too high (any of these seem to be most common).
regards, Bob
