newbie 101 ?
jmhulsey
GA
O.K. i just bought a 101A i think, 3/4 ton anyway. I need to wire it to a 7 way plug. Can I get some help? The left tail light seems to be some diode style and the right normal bulb. Why is that? Also what bulbs should I use to replace the 24v bulbs. Thanks
wreckerman893
Possum Connoisseur
15,647
2,141
Just buy a set of 12 volts magnetic tow lights and leave the 24 volt system intact.
Zip tie the lights and wire on to use them and if you want to tow it with an MV just remove and store the magnetic ones.
jmhulsey
GA
Another question. Will the "Red Block" stlye light work on 12 volts? I have not been able to get anything out of them.
1,193
Blackout light.
Do yourself(and everyone else) a favor and download and read the technical manual for your trailer.
12vman
ky
o.k. I just bought a 101a i think, 3/4 ton anyway. I need to wire it to a 7 way plug. Can i get some help? The left tail light seems to be some diode style and the right normal bulb. Why is that? Also what bulbs should i use to replace the 24v bulbs. Thanks
oh crap!!!!!!!!!!
Release the kraken!!!!!!!!!!!!
