Newbie Fixing a M101A3 Need Help
zakattackman
Sacramento CA
I just picked up a M101A2 and plan on fixing it up to be a Camping/Utility trailer.
My trailer never came with a surge brake resivor cap and I was wondering where can I get one as well as the pin used to lock out the use of the brakes for backing up?
Im sure there will be many more questions down the road; thank you for having such a good forum to answer my quesions
.:lost:
scrapdaddy
11
Dittmer, Mo.
The surge brake is a common brake, so parts can be found at any good trailer supply place or E-Bay. Use the TM's, they have alot of good information in them. Tractor Supply has the correct pin also.
islandguydon
783
Michigan
Any equipment rental or trailer shop should have the part. Measure the cap, fine or coarse thread, then find one off something else. Good luck, WELCOME...btw
zakattackman
Sacramento CA
Well no luck so far I've been to 4 different stores around town with no luck for the resivor cap. Does anyone have any links to one available online?
I was able to get my plates today at DMV so that was a + :)
zakattackman
Sacramento CA
Take the surge brake off, so your rig will be lighter. If your using it for a camper. no real need for it.
Probablly going to go that route I'm pulling it with a Silverado 1500 and dont see myself needing them. Is it safe to pull it with the lockout pin in place?
If I remove the surge brake system is there a way to put the pintle hook back on?
KsM715
142
St George Ks
Need to find an a1 lunette. But as stated in other threads, if you dont need the brakes, just lock them out. By the time you do all the work to buy/swap parts your only losing 30-40lbs maybe. Not worth the effort to me.
IIRC someone said something about an early cj master cylinder is the same as the M101 cap.
scrapdaddy
11
Dittmer, Mo.
I believe it was a @ 65 cj5 jeep master cylinder. I would rather have the brakes working than no brakes. For a full size truck towing that extra 30 pounds is squat.
fredster67a
College Park, MD
Question Regarding the M101A2 Trailer Brake Shoes
Does anyone know where to find them ( NAPA, etc.))- need to replace the primary shoes as they are fairly worn - they look like they are GM or someting similar - thanks in advance
Fredster67a
