mdeboard
- 0
- 0
- Hagerstown, MD
I have a M1009 with two wires burned through near the glow plugs. I figure if I'm going to rewire two then I might as well reqire them all. I'm a bit confused about the fusible link wires. Are the .8 GRN wires the fusible links that are soldered to the .8 ORN wires? From what I've read fusible link wire is supposed to be 4 gauges smaller than the wire they are soldered to. And since the .8 ORN wires appear to be the same size on the diagram, I am more than a little confused. Thanks in advance.
