- 415
- 894
- 93
- Daytona, FL
you just kept driving with that noise and then the trans grenaded? What’s the cost of pulling the transfer case apart and replacing that thrust bearing?pull the drain plug from the transfer case...I had the same noise I thought was gear lash as well... it wasn'tView attachment 877450
it was the C6 Clutch Pack thrust bearing that grenaded ... $11k worth of retran and all is well
there's the rub..I did not wait until the tranny left me on the side of the road... I looked at all alternatives.. to remove the C6 Clutch cover is a huge ordeal.. either remover the tranny from the top..after removing the bed.. or remove the tranny from the bottom of you have a tranny jack that can support @1600lbs and the correct size vehicle lift. Then I thought , let's just get the plasma cutter out and and start nuking all the huck bolts and the cross member which sits behind the clutch cover, which btw does not grant enough space to remove the cover, let alone disassemble the clutch pack... after @2 weeks of consulting the LMTV Gods on this forum as well as FB groups... I said F-it.. retran is the only sure bet with the least number of downsides..you just kept driving with that noise and then the trans grenaded? What’s the cost of pulling the transfer case apart and replacing that thrust bearing?
