Newbie ? on M105 trailers
Stan Leschert
87
North Vancouver, BC, Canada
VALIUM, gentlemen, and if that doesn't work, a good big dose of Crown Royal.
At one point in time, you were a Newbie, too.
Be civil and constructive, or just be quiet.
I was OIC of recruit troop for a while, and our job was to train them, not to prove who was the biggest Anus!
12vman
ky
If you had just left out the part in red, this thread probably would have ended there and you would have had your answer without any of this mess. New members using sarcasm or having an attitude WILL draw fire. Everytime.
thats ok ....it keeps me warm
12vman
ky
I guess the thought that comes to mind after reading all these posts is
"Lighten up Francis"
its a internet forum..........only.......
And I will lighten up too.......
1,193
Now your starting to fit right in!:D
KsM715
142
St George Ks
rofl I would be banned in a heartbeat if I was allowed to drink and post at the same time.
3dAngus
102
Perry, Ga.
Anyway.... back to the M105. All newb's should keep in mind, when you buy your first M105 you also need a pintle hitch lift for raising up your pintle on back of the pickup. It's bad enough with no brakes, and the chains won't reach, so you need about a 12" lift to raise the trailer so it doesn't push down on your pickup so much. Following that acquisition, you need a bolt on pintle. All total, it is another $200 or so expense before you leave the house. Some 12vdc Walmart trailer light kits will also serve your needs, where they all have the same mounting holes as the existing 24vdc lights on your M105. Some people like the magnetic lights and have had great success without issue, but I have seen they taped and wired and everything else and they still fall off, so I guess some of these old timers just have super secret knowledge that even when passed on verbally, just don't seem to work for me. Use your own judgement, but do make sure you have some kind of lights at all times.
You can buy the elevated pintle hitch lift which is a 2" receiver at Northern Tool or Tractor Supply. The link below is an example. I recomment a higher lift one. Even so, regardless of WHAT you get, it will still push down on the pickup because the M105 sits so high on those 20" tires.
Consider it another expense of doing business, and don't leave home without it.
Farm & Ranch Pintle Mounting Plate, 11 in. Shaft - 1891593 | Tractor Supply Company
http://www.tractorsupply.com/farm-ranch-8-ton-pintle-hook-with-6000-lb-ball-1890783
benand117
cuyahoga falls, oh
I think a lot of people on here think that the more posts that have the more improtant they are to the forum. So they find themselves posting thinkg that have nothing to do with military vehicles just to hit that big number. Who cares people? The man had a question. If you have an answer give it, if not leave it alone.
