Newbie Question
Christian
OKC, OK
Hello all! This past week, I found an irresistible deal on a 1985 M1009, so I had no choice but to snatch it up. The only problem is with the starter. After reading the FAQ's, I found out that CUCV's are quite notorious for starter issues. Since you are all experts, I was hoping you could help to diagnose mine.
Everything seems to be in working order except when try to start the truck, you can hear the starter spinning, but it isn't engaging. I already tried tapping the starter (which quickly escalated to beating the crap out of the starter), to no avail.
Thanks a million!
Christian
marks86
Latham NY
Assuming you have proper voltage, Pull the starter out and bench test normally when the starter is just spinning it means it doesn't have enough power to push the gear out to make contact with the flexplate
markg
hutto,tx
..... or you have no teeth left on the flex plate. common problem but not easy to fix. good luck. ive seen them so bad that you had to grab a belt and try and roll the motor over to a better spot, not easy with a diesel!!!!
Warthog
248
OKC, OK
Welcome to the site.
Always start any electrical troubleshooting with a set of fully charged and load tested batteries. Don't assume anything. Check them.
Then start testing the starter.
Warthog
248
OKC, OK
You location needs to be listed as a single state, not all of them. Site requirement
As a 16 year old you might tell us what your skill sets are. Have you ever worked on diesels? Electrical systems? Know how to read a troubleshooting manual and wiring diagrams?
phil2968
Lakeland, Florida
Probably a bad Bendix. It's slipping. The motor does not turn until the solenoid has pulled the Bendix into the flywheel and makes the contacts at the end of it's stroke.
