Newbie's First Post
Bravotroop
-1
Bozeman, MT
Hi, everyone. I drove a Deuce when I wore the uniform 'bout 30 years ago...loved them and now plan to buy one. One for sale locally turns out to be an M275A2 with 12-foot cargo bed, not M35. Is this truck essentially the same as an M35? Seller claims it's a Kaiser with Hercules motor. Thanks!
simp5782
Feo, Fuerte y Formal
9,366
Mason, TN
Similar. Probably Non turbo multifuel. The manufacturer is correct.
Sent from my SM-G935P using Tapatalk
tobyS
833
IN
Welcome Bravotroop. I googled an M275A2. It comes up the semi tractor version. Maybe they converted it to a cargo. Since tractors are usually the shorter wheelbase, does it have a lot of bed sticking past the frame?
It's a good time to learn how to post up some pictures. If your in the market for one, lots of guys here can set you up. Have fun.
Bravotroop
-1
Bozeman, MT
Thanks. Maybe there's been an engine swap...there's a multi-fuel TURBO motor under the hood, hi/low range lever between the seats, no six-wheel-drive actuator. Seller claims it's automatic when wheels slip (???). Will have my son snap some pix tonight.
Bravotroop
-1
Bozeman, MT
Thanks, 98G. Even if Sprag isn't the preferred actuator, does it work? I can't choose what's aleady on the vehicle. I hope to pack all my stuff in the 12-foot cargo box and relocate out west. I'll need good six-wheel drive to climb up a dirt road on a mountain.
98G
Former SSG
4,418
My personal opinion about sprag vs air shift transfer is that it isn't such a big deal. In the deuces, they are thought to be more fragile than the air shift variant. They have much less tolerance for allowing the vehicle to roll backwards while in a forward gear.
Sprag transfers work just fine in my experience.
Deduct about $700 from value for a sprag, and many buyers won't even look at a truck with a sprag transfer.
Gralmk
53
Attleboro, MA
Hi Welcome from Mass! Like stated pictures help, without them everything is based on what you stated so far! The M275 was early Deuce Tractors, and not as many made, compared to the M35! The bed if you need it does matter, is it a M105 trailer bed or a cut down M35 bed, either way it will haul less than an M35 I'm sure. But being shorter it will be easier to maneuver! As for the SPARG's well the Army got rid of them for a reason! You have to be careful when backing, it can be damaged real easy, the engage when the rear wheels slip, so no way to put the front Wheels in lock at your choice! There are kits to convert them over to an air shift but rare as well. But like any MV, depending on price condition and your maintenance skills, it's all about what you would like. Parts are everywhere for the most part!
Good Luck!
glcaines
2,586
Hiawassee, Georgia
I personally wouldn't touch a sprag unless you intend to convert to air shift. When I was in the Army in the 1970s, sprags were everywhere. You need to be careful when backing up. I have also had sprag units engage when driving at highway speed. The steering wheel starts jumping around and loud banging noises. They can also engage on the highway and wear your front tires quickly. Air shift doesn't have these problems. In my experience, the only way to cause damage with an air shift is to engage the front axle while moving and the rear wheels are slipping.
Bravotroop
-1
Bozeman, MT
Thanks. I was ARMY (19D cav scout) in 1980s-90s, got out once Desert Storm was over. All our Deuces were air-shift. Today here on SteelSoldiers is the first I have ever heard of Sprag. Soooo, is the Sprag a deal-breaker? What is involved in converting to air-shift? I agreed on terms with the seller today, but hedged that the deal isn't final until my son sees the truck tonight or tomorrow.
winfred
10
port allen la
i converted mine to air, it's a simple unbolt and bolt in swap if you ignore the fact it weighs almost 600 pounds, once you get past that T into air under the dash, add a switch then run a copper line down to the piston, a handy engine crane and a furniture dolly do most of the hard work.
mine kicked into 6x6 the first time i took it on the highway, removed the front driveshaft after that till i installed a airshift, was not interested in trying that again
Bravotroop
-1
Bozeman, MT
Thanks, Winfred. Anyone know where to get an air-actuated (name?) transfer case? I'm competent to do as Winfred says, but I may be old-and-tired enough that I prefer to pay to have it done, instead. Cargo racks/tarp, too. I had to fabricate everything I needed for my 1948 International KBS-6, and it tired me out LOL. I'm in Central Virginia.
Tracer
13,912
Hawthorne, NV.
I'm sure a member here has one in good condition. I personally would love to have a nice M275A2.M275A2.jpg Welcome aboard from Nevada. Lots of good off roading out here.
Bravotroop
-1
Bozeman, MT
Thanks, all, for the welcome and advice. I'll get pictures of truck once the sun comes up, and learn how to post them. If I drop the input shaft to the sprag transfer case, truck is okay to drive at 40-45 mph, right? Working with seller today on brake lights. Hope to get Virginia tags/inspection tomorrow. Maybe (crossing my fingers) rear axels alone will get me up the mountain.
gringeltaube
Staff Member
2,518
Montevideo/Uruguay
... If I drop the input shaft to the sprag transfer case, truck is okay to drive at 40-45 mph, right? ...........
No, don't do that; it wouldn't move at all...!
:).... I know you meant to say front "drive shaft" or more correctly, "propeller shaft". And yes, that's okay.
