Newbie's First Post
Hogwaller
Ault/Colorado
Roger that, DavidWymore. Will go to air once I locate a T-136-27 air unit. Currently has T-136-21. Tires are all 9.00-20 8-ply (in reply to 98G). In reply to GICaines, 18" aft of steering box frame shows three lines top to bottom (1) 22-2793-L (2) July 14-66 (3) 7529034. Pic attached. I can't decode those numbers. Triple-posted frame picture in case of shadows.
I've got the exact same numbers on my M35a2. Everyone that I speak with indicate that there should be a Serial number stamped in the frame. I have yet to find it! My truck was "rust proofed" in 1991, resulting in a thick undercoating on the frame that is hard to remove and likely covers the serial number.
Tracer
14,432
Hawthorne, NV.
Hog, my Deuce is an 1971 M35A2C, your frame number should be on the frame right behind the left hand front tire. Use very light sand paper or paint stripper. Just checked mine, it's still there. Should match the number on your dash ID plate. Hard to see in this pic but it's there, in front of the long bolt.DSCF2520.JPG
Davidwyby
244
CA
My earlier post was incorrect. The truck’s serial number will be further forward closer to the spring hanger.
Tracer
14,432
Hawthorne, NV.
Dave, your correct. To narrow it down, it'll be between the steering box support bracket and the long bolt in the picture I posted. Here is a better picture.DSCF2522.JPG
HN6
402
alaska
The transfer case is sprag instead of air. Air transfer is the preferred variant.
You're in VA. I sent you a link you'll want to read. (Not a sales pitch).
will you send me the link if you still have it... thanks
