Next Step for a "No Start"?
Warthog
245
OKC, OK
As a matter of fact there is some pictures of the two drive. In the link treads above.
http://www.steelsoldiers.com/592963-post27.html.
The direct Drive is on the left and the smaller Gear Reduction is on the right.
What does the bracket look like? Straight? Curved?
http://www.steelsoldiers.com/590862-post6.html
More that likely they changed the starter and didn't get a new bracket.
The only way to know for sure if the starter needs any shims is to pull the flywheel cover and check the spacing between the bendix and the flywheel. This is also covered in the above links and the Tech Manuals.
http://www.steelsoldiers.com/569854-post14.html
OD Heavy Hauler
Halifax Co. N.C.
Warthog, the bracket is bent(45 degrees or so). My starter is a gear reduction because it looks like the one on the right with the exterior bolts on it. I'll have to get another bracket when I put starter back in. Thanks
OD Heavy Hauler
Halifax Co. N.C.
Warthog- GM changed the part that goes with #10456116. It now lists some sort of brake control part instead of a solenoid. I'll look on the site some more. If you find something let me know and I will do the same.Thanks
