Nhc-250 fuel leak?
my blood flows OD
strafford new hampshire
I started doing the dual fuel line mod and I noticed it seem to be a little wet between the 3-4+5-6 valve covers around the little hooped fuel lines. Is this a common leak area?
If so what needs to be replaced? O-ring? Is this a Cummins only speacial part?
I don't want to take it apart and disable the truck till I know where I can get the parts.
3,164
Its called the fuel jumper. The screws can be very tight, use a bolsterd screw driver with a good flat blade, not all worn out, to get them out.
3,164
Just make sure you get an o-ring that the low sulfur fuel won't attack, viton or I believe buna-n. Just a plain rubber o-ring might not like dieselgas
