NHC 250 Inj Pump fuel leak
randygk
Nampa, ID
Our M923A1 runs fine but seems to need priming the fuel pump after setting for a month. Not a big deal until today when I noticed fuel dripping from the back (cab side) of the pump when idling.
If my research is correct it's coming out of the fuel damper on the bottom. Doesn't appear to be coming out of the hole. Is this a serviceable part (replacing gaskets and/or internal parts) or do I replace the whole unit.
Any help or suggestions are appreciated.
Thanks
randygk
Nampa, ID
I ask these questions first to avoid a gotcha or oh crap moment like " be careful there's a spring that flies out when you remove it, once you break the seal, or no user serviceable parts inside". I found the fuel pump damper parts view in the TM and removed it no problem. Going to Cummins dealer today to get the parts. They had all the matching part numbers in stock except for one, and they think that number has changed several times to a new part number they have. The fuel pump gasket kit listed by Stickey (who is this guy) has the parts for the damper in it, but cost is $ 97.00. The separate parts are about $ 20.00. Also found my pump inlet fitting slightly loose, probably my loss of prime issue. If not I will look at the primer pump and hose.
Will post results.
Randy
randygk
Nampa, ID
Cummins dealer was very helpful. Replaced all parts in the damper and changed the fuel inlet fitting O ring. No leaks and will have to give it time to see if the prime issue is solved.
dstang97
30
Clover, SC
I have a pump leaking from the same place. How did you Make out fixing the leak? Do you still have the Cummins numbers?
Choppers
Missouri
You did have to pull the pump, right?
Did mine by pulling the pump.
Way beyond my skills and tools.
Got -r - done.
Haven't blown up or caught on fire.
randygk
Nampa, ID
Seeing my old post caught me by surprise. Yes it did fix the leak, no didn't need to pull the pump. The loss of prime was the flex supply hose to the pump, didn't leak fluid, but sucked air.
I sold the truck when moving to Idaho in mid 2017. I see a few 5 tons here in the treasure valley, sure miss that truck.
You all be safe, enjoy the green stuff.
