Here is some other useful information. I replaced mine yesterday just cause they were a slow seep. The fitting that is the screw on fitting on both hoses is a 1-5/16-14 PTT thread. 30 degree flare. It is not a 1 - 5/16-12 that is a JIC. It will not seal it self down on the flare, Plus the showing threads are fewer than a JIC inside of it. You can however replace the fitting into the pump with a JIC adapter to make it work like I did in my one picture. My guys couldn't reuse the old fittings. One was a little chewed up from someone trying to crossthread it before. It is also a 7/8" ID hose. 3/4" hose would work as well. I don't think it would hurt flow rate.
I did have a guy willing to mill me out a block to replace the housing on the lower part of the oil pan that would be larger in diameter rather than the oblong angle drill out that cummins did... More oil flow perhaps? I am looking at adding an oil cooler up front.
Parker series 20 swivel fitting part number 23220-16-16. The male ends of the hoses are just standard pipe Parker number 10143-12-12
