- 7,422
- 2,531
- 113
- Interlachen Fl.
As stated before it is just a airdryer can be added to any truck. Nothing to do with CTIS just keeps out the moisture.
Well all I can tell you is my A3 has the CTIS system pulling the feed air from the inboard tank. That would be compressor, air dryer then tanks.On the other hand...after doing some research the dryer is only used apparently used by the CTIS system. So if you do disconnect it you'll be putting air that may have moisture in it into your tires. There are several manufacturers listed for the dryer. The one that can be referenced , Haldex, is at this website: http://www.haldex.com
Their part number is: N4250B
Also, I have attached the parts list for the Dryer assembly:
right click and open it in another window.
Have fun!!!!!![]()
