hvillem1009
- 0
- 0
- Pelahatchie, MS
I haven't been on here in awhile. I searched the forums to see if I could find anything similar. I am having a problem with my m1009. I had to replace the batteries due to bad swelling on both. I put the new batteries in and went to crank truck. I took voltage readings, front 12.74 back 12.78 and then from negative front to positive rear and got 25.43. Inserted key and turned it to the first position to heat glow plugs. All dash lights came on, when the WAIT light went out I attempted to crank the vehicle. When I did this, all dash lights went out and nothing happened. Now I have no power to anything in vehicle. I took battery measurements again and from front to back I only got 12.8 volts instead of the 25.43 before I attempted to crank. I have been checking all wires and can't find anything showing a short or open. All the fuses are still good. Can someone please give any advice on what I need to check, or any other suggestions?
Thanks in advance.
Thanks in advance.
