No brakes M813
zxmedic
Canada
Hi gang the Noob here hope this is the right place to post this
So Picked up an M813 Friend and old owner stated that the brakes just failed pedal to the floor .. Working on the truck today I looked at all the lines found no leaks Nothing running from Drums master cylinder is Bone dry ... Airpack gone ?
Any help would be great
Cheers everyone
P
dburt
NE Oregon & SW Idaho
If the master cylinder is bone dry then there is a brake fluid leak somewhere. Fill it up, start bleeding the brakes and adding fluid till you find where the leak is. Remember, the 813 has air assist over the standard hyraulic braking system, so if the pedal goes all the way to the floor, there is not enough brake fluid left in the system to do any good. You have to find the leak and fix it!
wreckerman893
Possum Connoisseur
15,618
2,013
Good question- we need wreckerman or some other helpful person to chime in on this!
DAMIFINO I'd fill it with fluid and have "Soldier B" pump the brakes while I bled the system. It could be leaking from a wheel cylinder, line or the master cylinder/air pack. Make sure you bleed it starting with the wheel cylinder farthest away from the master cylinder. If you see no leaks right away let it sit on a surface where you can see leaking fluid standing.
porkysplace
1,487
mid- michigan
You also need to bleed the air-pac.
swbradley1
Modertator
1,612
Dayton, OH
Get a helper or use a Motive Brake Bleeder or make your own bleeder.
If the pedal goes to the floor it's a safe bet there is no fluid. Fill it and bleed the fitting on the air pack first and then farthest wheel cylinder to the closest. If you get it bled and the pedal is hard and does not go down much chances are the air pack has a problem. You can try lubricating the air pack and exercising the snot out of it to see if it will free up. If not, replace or rebuild.
zxmedic
Canada
thanks again Guys I have three hard copy booksfor the truck ,,, going to download a few that porkysplace set a link to awesome
73m819
319
gainesville, ga.
The M/C gets BLED FIRST, then the air pack, then left rear, right rear, left center, right center, right front, left front,
Look for a wheel cyl., m/c or rubber hose (there are 5) leak, NO matter if a hose leak is found or not, REPLACE ALL 5 RUBBER HOSES unless you KNOW they have been replaced not to long ago, if they have NOT been replaced, there is a good chance they are ORIGNAL.
porkysplace
1,487
mid- michigan
This is a good thread on building your own brake bleeder ; Deuce Power Bleeder R4x4 Style
