No brakes M813
1,172
It has a hoodscoop!
zxmedic
Canada
Yes it has a working knuckle boom. I bought this truck from mil spec industries . Huge thanks to him and son .
zxmedic
Canada
Thanks again guys for the help ..the trip showed me where the leaks are the seal on the short driveshaft is leaking and the inner axle
bigmike
355
Dixon CA.
Be careful!
Brake fluid doesn't just evaporate. If you refilled and bled the system and did not find a leak or failed component, you have not identified the problem. I had the same issue with my wrecker. I filled the fluid, bled everything and had no issues and no leaks. Then suddenly, no fluid and NO BRAKES. I ended up replacing all wheel cylinders, M.C. and airpack. I found mulitple wheel cylinders with small leaks that did not produce any external signs of leaking
You need to be sure your truck will stop. For your safety and the safety of those around you.
zxmedic
Canada
Thanks bigmike. That's my plan and since the axle seal is leaking on the drivers inner axle it's a sooner then later job being a paramedic by trade crushing people is not high on my list of job discriptions . My whole intent was to get it home so I could work on it during the down time .. anyone know if the tranny has to be pulled to change the seal on the transfer case it's leaking front of the short drive shaft .
zxmedic
Canada
All new seals will be going in once the weather breaks I found a supplier for the rivets and a shop here that will turn the drums and set the new linings on for me . I had to deal with this problem first uploadfromtaptalk1393268045412.jpg
