No Dash Lights in M1009
tgtaylor64
Florence, SC
The 5A instrument fuse is good but no lights. Indicators, high beam, and blinkers work. I cleaned the instrument cluster connector and have it firmly seated. I have verified that the lights are good and have cleaned/greased the connectors. Batteries are good and load tested. Any suggestions?
Warthog
244
OKC, OK
Have you tried turning the knob on the headlight switch?
Do the headlights work? The headlight fuse feeds power to the headlight switch which feeds the instrument panel bulbs
Warthog
244
OKC, OK
Check for power on both sides of the fuse. If none then your headlight switch may be bad.
swinters
9
Olympia, WA
I've seen a number of times where all of the bulbs burned out quickly after a couple of others did. Theory explained to me by Chevrolet when the CUCVs were about a year old was that as other bulbs burned out the remaining ones in the same circuit burn hotter and burn out quickly. Ohms law seems to support that. They recommended using long-life bulbs as replacements.
MarcusOReallyus
819
Virginia
Um, no, it doesn't.
tgtaylor64
Florence, SC
Checked for power on both sides of fuse. After putting in no less than three 'good' fuses from the shop, I decided to pick up a fresh pack of Buss fuses at Autozone while I was having my rebuilt alternator tested. Guess what, they now work! My guess is that I had oxidation buildup on the fuse holder and the constant insertion and wiggling around cleaned it off. As a wise man once said, if it is electrical, clean it.
On a somewhat related note, I decided to clean all battery posts and to replace some cheap cable ends with high quality ones made from 000 welding cable at Richbourgs in Florence, SC. What a difference! I was able to 'find' an additional 2 Volts and now I am getting almost 29VDC across both batteries and at the dash voltmeter.
