rynomadman
- 0
- 0
- United States
no the problem you described is the very same thing it is doing. its just like its in neutral when you push the shaft all the way in. it will go in low 2x2 and 4x4 no problem it does like to pop out but think thats just because there is nothing to hold the shaft for high and low where it needs to stay. going to get a e brake leaver for it.. the way the air is set up its just hard lined from a tank with a valve to give air to the front cluch and then the other way for the reverse. From what i was reading on here was thinking it was bc the there was air still in the line holding the front clutch in.. So just to be clear to shift from low to high I need to have no air going to the t case and all i have to do is push the leaver all the way in? Or does it need air to declutch then it can be shifted? being that I did not build the truck and nothing is labeled its hard to figure out.
