No low beam.
tankie88
Redruth,Cornwall,England
Hi all.Just getting the truck back on the road.Was testing the lights.I have no low beam.The headlight mod has been done a while ago.Fuse ok,both relais ok.Main beam works(after a couple of flicks).Parking lights all work.One more pull on the headlight switch should turn on low beam,but doesn't.Is the light switch faulty or high/low switch.Or a combo of both?
Evil Dr. Porkchop
276
Colchester, VT
I've had similar problems with a faulty high/low switch. My headlights would work once every 50 or so clicks until I changed it out. So that might be a good place to start if you know both headlights are good.
cucvrus
10,354
Jonestown Pennsylvania
That switch can be a bit challenging to change. It is easy when you take your time and do it in a cool place. Be careful and adjust it properly. It slides on the column and is easy to change. Tiny fasters. Mine was made by Singer sewing machine company.
