no power at firewall for ignition
meb831
holmes n.y.
have a m1008 no power to the purple wire that goes to the starter. changed relay under dash still no power,also new ignition switch also have already done the 12v conversion
Warthog
231
OKC, OK
Did you check for voltage at the under dash relay? Also what did you replace the relay with?
The purple wire passes thru the firewall at the wiring harness block next to the steering column. Sometime yo need to take the block apart and clean the contacts.
The relay sends the 24v to the starter. The 24v is supplied via the very bottom fuse.
the wiring diagram is in the appendix of the TM 9-2320-289-20 manual. All the manuals are avaiable for free. Just click on the Technical Manual button at the top of the page.
Warthog
231
OKC, OK
Not trying to start any trouble but one of the rules of this site is that everyone is to "try" to use capital letters and correct punctuation, spelling and grammar.
Warthog
231
OKC, OK
Reread your post. You say that you have done a 12v conversion. Why? How? What did you change?
With a 12v conversion it makes it much harder for us to help diagnose electrical issues.
meb831
holmes n.y.
Removed the drivers side altenator and hooked the batteries 12 volt also installed a 12 volt starter. Has been working fine for six months now no power in the starter wire
meb831
holmes n.y.
Wanted to give some more information. When trying to start turn the key and everything functions normal. Glow plugs cycle and all inside and outside lights work. But no power for the starter.
Warthog
231
OKC, OK
Do you have a multimeter and know how to use it?
You need to test the underdash starter relay. You are looking for 12v at the red wire and 12v at the purple wire with the key in the start position.
Also did you disconnect the big glow plug resistor pack when you switched to 12v?
1,175
Also, test the purple with white tracer wire(under dash relay plug) for 12v when the key is in the start position. That is what triggers the relay.
You can simply splice it to the purple wire and eliminate the relay since you "converted" to 12 volts.
Warthog
231
OKC, OK
That would mean the relay was not functioning.
Glad you got it working.
