sermis
- 17
- 38
- Temple, TX
Not sure what is going on here. Truck is really hard to start and RPM's are low until warmed up and still not power. If weather is cold I have to use starting fluid and still might not start. Today it started but RPM's are still slow and truck has no power. Will not pull in 5th at all. EGT's are going up to 1,100 - 12,000. Motor temp stays at 180 on a 3 mile trip around the block. Does no look like too much blow by from the slobber tube. Any ideas? Turbo maybe? Hearing issues and I can't hear if it is spooling or not. Fuel is a lot of oil and some diesel.
