Gunfighter1
- 0
- 0
- AZ
So i replaced the power steering pump, got a unit from Rock auto as it was alot cheaper than the local parts store and they didnt have one in stock. I also replaced the high pressure lines and return lines and all the belts while i was at it. All new parts in, bled the lines by pumping the brakes a few times and turning the wheel. Start it up and went for a drive and the power steering barely works at idle. When you stop youve got to man handle the wheel to make a turn and the brakes are really mushy. Could i have gotten a bad pump? I tried to re-bleed the lines again and tighten the belt but the same thing happens. Theres no squeal or whine coming from the pump or anywhere, fluid is full and no bubbles come up when you manage to turn the wheels. Im stumped. Really hope i dont have to take it off and replace it again.
