No pressure multi-fuel injection system
kaiser2help
East Freetown, MA
My m54 5 ton has no fuel pressure between the secondary fuel filters. I am tapped into the bleeder port in that location, can hear fuel pump running, but no pressure. Can anyone help?
WillWagner
2,467
Monrovia, Ca.
Maybe the plate fell off the bottom of the in tank pump.
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
If the pump is on, is there pressure at the primary? Drain it first, then take off the bottom of the housing. Turn on pump. Got fluid? If no, the bottom fell off the pump. Let me know and I'll show some pics.
kaiser2help
East Freetown, MA
Well I have removed the primary and engaged the fuel pump and boy can I tell you she is pumping. I have converted he primary over to the spin on with a flow rate of 12 to 15 gph. Any suggestions ?
1,814
Check for smashed fuel lines. Go to the primary and if you have fuel at the discharge side, follow that line to the next junction, open it. If you have fuel flow there go on to the next junction. Continue doing this until you have isolated the problem and fix that.
gimpyrobb
27,785
748
Cincy Ohio
Is the line under the radiator open? Some of them get crushed, and I have even seen the rubber part that connests to the ip get stopped up by junk. So I would say, take the fuel line off at the ip, make sure fuel comes out. If its good there, it should make it to the sedcondary and final filters. Anyone else?
