"No preview times available": What to look for?
rchalmers3
30
Irmo, South Carolina
Sorry for the newby questions, I'm just joining the olive drab frat.
I am considering bidding on a truck being auctioned at a location that has no preview times available. The vehicle description on the GL website says the VIN is: 4M-4048.
What can y'all tell me about the truck from this scrap of info?
If it's an M35A2, it's supposed to have a turbo, right? The reason I ask is that when I click on the "more info" tab in the Item Manifest box, the nomenclature reads: LD465-1. Can someone please "'splain" this to me? The photo indicates that their may be a turbo hanging under the plenum on the passenger side of the motor. Wadda ya think?
Should I call the base and ask to speak with someone who can tell me about the truck? Will they talk to me?
Advise and opinions welcome.
Cheers, Rick
FreightTrain
Banned
2,730
13
Gadsden,Al
No,Not all M35A2s have turbos but the one above does.
M35 Gas powered
M35A1 LD427 Multifuel(N/A and Turbo)
M35A2 LD465 Multifuel(N/A,C and D turbo)
M35A3 Cat powered with automatic tranny,CTIS,Fugly front end,computer controled
rchalmers3
30
Yo FreightTrain,
Is your reply based on the photo evidence or the VIN?
Is that really a VIN? how is it coded?
Thanks,
Rick
ida34
36
Dexter, MI
I was just looking more closely at the pic and it looks like some parts may be missing. I don't see the air cleaner tube connected to anything. The turbo may be missing but the air cleaner tube pointing down like it does indicates it is a supposed to have a turbo.
Jake0147
Panton, VT
GL pics can make it look like nothing's been smashed with a forklift when it has, maybe they can make it look like parts are missing when they're not. But it sure looks like the air filter housing outlet tube is a dead end...
Here's my attempt to duplicate that photo on a turbo engine.
rchalmers3
30
Chuck, you have a good eye for details! Jake0147's photo clearly shows the pipe routing (and an exhaust leak it appears) bending down then back to connect to the turbine inlet. The one I posted is either cut off, disconnected or just photographed in such a way as to look like it terminates in the air.
Given only the "reg" number, is there any more info available? Like year built, who built the beast and any other data specific to the truck? and what is the "reg" number? Is that the army's own ID number given to the unit? If there are records available, maybe it can be determined when this rig was put into service.
Thanks guys,
Rick
jasonjc
291
Gravette Ar.
You will have a hard time getting a truck from GL living in Costa Rica. You will need to go thought a dealer that has an export license.
Jake0147
Panton, VT
...and an exhaust leak it appears...
/quote]
Nope. it's a continuation of valve cover gasket leak and the slobber tube adapter to the valve cover gasket leak. I'm gonna fix those one day. But it's a good case in point about looking at internet pictures. Having looked at the truck, I know I'm right. Looking at the picture, had I not seen the truck, I'd be convinced that you were right.
rchalmers3
30
You say the engine is supposed to be a LD 465-1 thats a non turbo engine or it would read LDT 465-1 I believe. I have two non turbo trucks and they are both LD 465s.
Yeah, as I said, the GL "more info" data conflicts with the pics. The data indicates a N/A motor, but as the other gents have noticed, the motor appears to have (or had) a turbo.
Is this normal? One possible explanation I can think of is that the data presented on the GL site is representative of how the truck was originally built, while the pics reflect a turboed motor from a re-manufacture.
Can anyone shed some light on this?
Rick
rchalmers3
30
Brief hi-jack of my own thread: ON
Sounds like the typical GL auction. Could be an M35, could be a VW, who knows? They don't.
I'd be wary of it, because it may not even be what you end up winning if you bid on it.
That's scary! BTW, who prepares the lot photos and description? Is it the DRMS or GL?
hi-jack: OFF
Rick
randyscycle
Rhoadesville VA (where!)
As far as I understand, GL goes on what they are told.
I don't buy it totally though, as I've seen trucks nowhere near what they are depicted as in the auction pics and description. If I can't look at it very carefully, I won't bother.
