No rear taillights help
jut
chest springs pa
Hi all new here. Just got a 86’ and the rear taillight harness was missing. I had a harness from a 77 k20 that I thought I would use but the wiring is confusing me. The truck harness has 2 browns, 2 dark greens, 1 lite green and 1 yellow. My question is what’s the extra wires for? If I hook up the one brown and yellow and put the left turn signal on I get side marker and running lights both come on but no flashing. They are also lite very dim. Any help is appreciated. Thanks!
Barrman
2,231
Giddings, Texas
Welcome to the fun. At the top of the page there is a tab labeled "TM". Open that tab then click on the very first thread called "TM's for the CUCV." Then open the one that ends in -20. Appendix F of that manual is a complete very detailed wiring diagram for the entire truck.
The CUCV wiring for the lights is just a little bit different than the civilian because of the black out light system when the years are the same. You taking a glass fuse wiring system and putting it on a blade fuse truck could be part of the problem. That same -20 manual has a great electrical troubleshooting section that will also talk you through everything.
jut
chest springs pa
I see the brown/w and dark green/w are for the black out lights. That’s a start I can eliminate those 2 wires. Thanks for the help
