infidel got me
- 34
- 48
- Newberry, Florida
I'm putting the finishing touches on the 923 after painting. Had a little free time today, so I figured I would install my headlights. Easy enough-- well not really. So, this is what we are working with. 7 inch glass lenses w/ hella 24v bulbs. Drivers side works fine, passenger side has no low beam. I have no voltage/power on # 17 wire on passenger side. Took driver side bulkhead connector loose and checked continuity between #17 at pass.headlight and bulkhead connector--have continuity, also cleaned grounds. So, my problem is from the headlight switch out. I did look at switch wiring diagram and it was kind of vague. Keep in mind that everything else is working correctly--just no power on#17.
