spicergear
- 26
- 0
- Millerstown, PA
I ran my 931 last weekend pulling pine trees down and it worked great. I came up yesterday, hopped in, flipped the battery switch, it made it's typical couple of noises, flipped to run, then start and all it did was turn over with no start. This truck's 6CTA has ALWAYS started within about a second of turning over. I tried a few times cycling battery on off, etc with no luck.
The big solenoid on the main engine kill at the IP is working as it should and the lever on the IP is moving fine but I can't hear if the solenoid on top of the engine mounted fuel pump on driver's side middle-rear of block is working. I know on other stuff I've heard those solenoids make an audible click. On the CAT in my crane truck, I can hear if click from in the cab.
I gave it a tiny sniff of ether and if fired so I know I'm getting no fuel.
Anyone run into this yet?? Can anyone with a 939 series truck with the 6CTA check to see if the pump solenoid makes a click you can hear or feel?
Anyone run into something else this could be???
I need this truck mobile!
Thanks!!!
Thanks!!!
