No Start M1008
Greatthumper
Audubon, NJ
I turn the key and nothing. Starter does not engage, starter does nothing. Checked all fuses in the box. Charged both batterys. Tried again, same result. Any thoughts?
1,172
42. ENGINE WILL NOT CRANK (NO AUDIBLE CLICK FROM STARTER SOLENOID)
Step 1. Check 20 amp ignition fuse. (See paragraph 4-12)
Replace fuse if burned out.
Step 2. Perform
Electrical Troubleshooting malfunction #5.
To figure out what malfunction 5 is, open the -20TM and look in the troubleshooting section.
MarcusOReallyus
813
Virginia
Only the military would have numbered malfunctions.
:mrgreen:
Hey, wasn't there a popular song about that way back when?
"Malfunction #9", I think it was called....
Cue Weird Al! :D
Greatthumper
Audubon, NJ
It was the starter relay. I did the Doghead Conversion. Truck started right up after I pulled the starter and replaced the relay. Thank You all for your help. Thank You Doghead for the conversion.
