No start, please help
Bigbondo007
Arabi, ga
Help please!
84 m1028. Truck sat for 2 days, went to start it and didn't set the fast idle and the truck shut back down. Starter made a noise so I checked it after the engine shut down and had to put another bolt in. Tried to start the truck and it'll crank but not start. Getting fuel pressure in and out of the filter, getting small spurts at the injectors, pulled top of pump and its full and verified function of the shut off solenoid and the advance. Engine will start with fuel dumped in the intake but the truck won't start on its own. I'm out of solutions.
Sent from my SM-N950U using Tapatalk
Keith_J
1,316
Schertz TX
Check the metering valve under the injection pump cover. With cover off, simulate the action of the engine kill solenoid, looking at the metering valve. It should rotate slightly when you release.
