NO START without ETHER !!!???
Floridianson
2,537
Interlachen Fl.
Tomorrow, I will increase the main fuel. James what would have changed to require the increse?
I would be guessing but head going bad. By increasing the main fuel I'm hopeing it will close down the control coller some and make more pressure and help in starting. If this works you can then back down the main fuel nuts to where it will start easer and but not be high enough to melt stuff . You will be fine just mark the inter nut with marker and count rotation.
Call me if needed 352-262-0398
Floridianson
2,537
Interlachen Fl.
Increasing the fuel did not help as Tim pm me. From here I might read tm troubleshooting the 465 and go step by step. Tim if you need parts I might have what you need. I'm bad about getting the parts out but I'm here.
Need to check all pressures from intank to full rpm numbers.
