No start
USMCWARWAGON
Lincolnton, NC
sorry guys its been awhile. I took my old injection pump off and replaced with a rebuilt pump. I can get fuel to the injectors but its not firing up. I can get it to run with off wd-40 but it wont stay running. I have spent the last 3 days bleeding fuel lines/filters. Not too sure what is wrong. Anyone have any ideas?
USMCWARWAGON
Lincolnton, NC
how do I check the timing, where are the timing marks? is all of this in the HH? i didnt think that HH was part of the engine timing, I know about the line up mark on the gear inside the HH, thought that was just used to remove HH from the pump.
M35A2-AZ
383
Tonopah, AZ
Lineup timing mark on the front of motor, make sure your cyd one valves are closed when your on the mark. That way you know your one #1.
Make sure the pump make is lined up, then make sure your HH is one tooth off to the rear.
Your pump turns the same rpm's as the motor, but the HH turns half the rpm's.
I just finished my pump rebuild and install and this is what I did.
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
Just make sure the red scribed tooth is visible! If not, its 180 out of time.
See my added note.
