No trans dipstick
jmmay82
Chicago IL
There is no trans dipstick on my 1096 m1009 and there is no spot to go where one would usually go. Is this supposed to be like this or did it get cannabalized at the gl yard it does not leak fluid and there is no open hole but the coolant lines
mkcoen
382
Spring Branch, TX
Trans dipstick should be on the right (passenger side) of the engine next to the fire wall. My stick broke and I picked up a Turbo 350 stick from the local speed shop. The stick is the exact same but I don't know about the tube (and it's chrome which makes it hard to read).
If the tube is gone and it's not leaking then it stand to reason that you don't have much or any fluid. The tube goes into the top of a lip above the pan so you might have to feel around for it. It's also on the right side of the transmission.
HAWKMAN
N.E. P.A.
Someone may have put a capplug in the dipstick hole and that's why it's not leaking,BUT I would get a tube and stick ASAP as it's VERY important to have the correct level of fluid in your trans:-D
hobie237
Newark, DE
There's supposed to be one there, it must have gotten cannibalized. No biggie, though, it's a regular, off the shelf part that should be in any junkyard for not much money.
