liljohn
- 0
- 0
- Grandville, MI
Ok, here's the situation. I have no turn signals or brake lights. It's not an uncommon problem I know, so I've read all the threads I can find here (and have started a couple of my own).
Up to this point I have:
A) Checked the ground and the wires at the flasher module, including re-mounting the thing with new bolts.
B) Disassembled, cleaned and tested the multiswitch
C) Dissasembled, cleaned and tested the turn signal switch, including sanding and cleaning the grounding area on the steering wheel tube
NOTHIN.
I've got all my Deuce manuals back in Ohio, not here in Michigan where my Deuce is. Anyone have the appropriate wiring diagram they could post so I can check this stuff out?
Can a shot flasher unit cause the brakelights to not work, too? Is there any way to test the flasher unit to see if it's working?
I'm reaching for straws here... I need to have this thing legally on the road at the end of December, and I'm not home much to work on it....
Thanks in advance, guys!
NOTHIN.
