Noise from generator pulley?? Free spins on shutdown.
nikojo
103
Wisconsin and Illinois
I'm posting link to video.
HMMWV Generator Pulley Noise
On start up no noise. Generator pulley spins and generator charges batteries fine.
On shutdown it makes noise and inner part of pulley/nut free spins for a few seconds and then stops.
This can't be normal?!?! How do I fix this??
  • Like
Reactions: OBX
Mogman
8,280
Papalote, TX
It has a sprag clutch in it to keep the torque from the spinning alt from causing the belt to squeal when the engine suddenly stops, sounds like it needs some lubrication.
Otherwise yes that is normal for that type of pulley, not all alternators have that type of pulley.
  • Like
Reactions: OBX
Mogman
8,280
Papalote, TX
You also need to replace that fuel line on the fan clutch (and any others in the power steering system), fuel hose does not have the temperature/pressure rating for that job, you should be using power steering return line, saving money here is not a good idea.
nikojo
103
Wow. Thanks for picking up on that. I'm going through the truck bits at a time. Didn't pick up on that and it explains a leak I noticed coming from connection at fan shroud.
Has anyone used AN connectors at these locations? Or is worm gear clamp adequate??
  • Like
Reactions: OBX
Mogman
8,280
Papalote, TX
Seems worm clamps are good enough, the hose on the inside of the fan shroud uses AN fittings (is not 3/8 hose ether)
Not sure about the nuts, consulting the TM should give an answer, others may also have the answer.
papakb
1,186
San Jose, Ca
I installed hoses with AN fittings on them on all of my fan clutch lines and will never go back to hose clamped lines again. There's a very valid reason they use them on aircraft and those same reasons apply to vehicles. The reason manufacturers don't use them is for cost savings but it's cheap insurance when you think about it.
  • Like
Reactions: OBX
nikojo
103
You wouldn't happen to know the fittings you used, ie sizes?
Retiredwarhorses
3,877
Brentwood, Calif
Steven what are your thoughts on the noise? Just lubricate at interface?
Is it possible it’s too tight or too loose?
Don’t understand how that goes together as the TMs I’m looking at show simple single but and key.
the noise is normal and it’s working as designed
Retiredwarhorses
3,877
Brentwood, Calif
Yes. And had I know what I know now I would have had you do it lol!
I’m happy overall right now but lots of things done poorly and have been slowly going through it. In the end paying for it again. For anyone reading this getting it done right.
so you have a converted M998A1…that makes sense now.
You need A2 and above TM’s
nikojo
103
I've tried oiling/greasing the bearing/clutch but can't make it go quiet.
If everyone says this noise is normal than so be it but it makes me anxious everytime as I associate this with a bad bearing or something borken.
I was able to switch out the line and it was perfect. No more leak and much more secure.
86humv
489
Texas
You were told Jan 9th that its normal.
Also...if bearing ever froze up...it would be a non-clutch pully and still work like the early non-clutch ones..
