rustystud
- 3,374
- 113
- Woodinville, Washington
I only covered the roof with some DynaMat trunk-hood insulator. I'm covering the floor with DynaMat Deck material.What did u put on top of it to cover it
Sent from my SM-G928V using Tapatalk
I have used this stuff on my CUCV, the M35, and the M54. It works exceptionally well. Easy to cut and work and really lasts. After cleaning the floors, painting with epoxy and spraying with Eastern's rust hogging rubberized undercoat, I apply NOICO matting. Less expensive but heavy to ship. I top everything with NECO 1/2 inch closed cell mat with vinyl type material attached.For those considering doing this there is a cheaper version of the dynamat material on amazon https://www.amazon.com/Noico-deadening-automotive-Insulation-dampening/dp/B00URUIKAK/
A friend of mine used it in his bronco and he's happy with it.
Beautiful job - I have worked with that stuff and it is not easy to get it done as perfectly as you have.
I knew I have seen that look before!! Needs some pink though!Beautiful job - I have worked with that stuff and it is not easy to get it done as perfectly as you have.
But you must admit the appearance is reminiscent of what Hugh Hefner's pajamas probably look like.![]()
I don't know if anyone else has tried the Jones Turbine - Aero turbine mufflers, but I installed a resonated one on mine and I like the sound note and it is quiet as well. Yes I did put the guard back on and I don't think my welds turned out too bad for my first time using my new Tig welder.
View attachment 649994View attachment 649995
Looking good !I am working on sound deadening too. This dynamat equivalent material first followed by closed cell foam and mass loaded vinyl. I will also work on the hood and side panels since they vibrate so much. View attachment 652471
